![]() | Home > Puma (Tdci) > Why the upgraded slave cylinder |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 ![]() ![]() ![]() |
Not sure Pat, there was an upgrade on the later pumas I think.
The newer slave has a bigger supply and a different spring arrangement. Make sure you get the slave cylinder and the adapter pipes. Also change the pilot bearing while you are in there. I found the easiest way was a engine crane through the door and a sling around gearbox just in front of transfer case with a bight to the rhs a small chain block to the back of the transfer to adjust level. Just be carefull as the engine crane goes close to the dash. Mark |
