Home > Maintenance & Modifications > Delocking a defender handles
j17
Hi
I wanted to delock my defender, it has central locking and I could get in through the boot if necessary (plan on installing security lock on rear door)
Can anyone confirm if the rear door handles fit straight into front doors? So I can buy a pair of bearmach rear handles and fit in the front doors
Thanks
Jit
Post #754255 27th Jan 2019 10:38am
Roy5695
You could just buy two passenger door handles no? My passenger door handle didn’t have a lock in them. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #754259 27th Jan 2019 10:52am
j17
Thanks
Actually looking at pics it looks as though the handle mechanism is different on left and right doors
I may try just removing the locking mechanism from the inside and putting a blank in or just let the lock spin, will take a look
Post #754265 27th Jan 2019 11:10am
hank
LR066529 is part number for the 'blanked' RH door handle
If you're feeling flush...
https://twistedautomotive.com/store/billet...r-handles/
https://www.nakatanenga.de/en/optional-equ...d-lighting > 110 XS Double Cab
Post #754270 27th Jan 2019 11:24am
grafty99
I've delocked mine. It didn't have central locking to start with so bought 110 second row handles when I delocked mine Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #754271 27th Jan 2019 11:27am
j17
Thanks
Post #754274 27th Jan 2019 11:36am
Roy5695
The lever on the handles are different from LH to RH but easily swapped over. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #754279 27th Jan 2019 11:56am
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Just disconnect inside the door, including the ‘button’ inside.
The lock then has no function....
Post #754345 27th Jan 2019 5:35pm
bankz5152
Pop the barrel out. Pop a grommet in. Done. Instagram @defender_ventures
Empire Tuning - Agent
Post #754355 27th Jan 2019 6:09pm
