![]() | Home > Puma (Tdci) > Bumper mounted recovery points |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 ![]() ![]() ![]() |
There have been a number of threads on this and views / opinions exchanged (some with stress calculations etc) but I was wondering if anyone has actual experience using them for a recovery. By recovery I am thinking mud based recovery such that you have considerable forces present rather than any road or minor field recovery.
So, any long term usage reports of products such as the link below......please ![]() https://www.4x4overlander.com/product/recovery-eye/ Sweatysock ------------- 110 CSW TDCI (Puma) 2007 |
m3vert Member Since: 15 Mar 2018 Location: Central Scotland Posts: 162 ![]() ![]() ![]() |
I have a D44 Defender Clubman Bumper - Low line Air Con Tapered bumper that has 2 double re-enforced recovery eyes on it. I have assumed they will be perfectly acceptable recovery points regardless of where I am stuck? Obviously not tested them yet but if I did have to I would be a bit cheesed off if they failed! Is that likely??
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
I have the Nakatanenga ones from Brendan but haven't had to use them in anger.
![]() Click image to enlarge Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
They do look smart
![]() 2008 SVX 90 2000 XS TD5 90 |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
I have them as well. Fine for straight pulls but when I had to pull a Patrol out of a ditch at a bit of an angle it bent that direction. Not too surprising I suppose as the metal is actually quite thin.
They look good and they are solid for occasional recovery. |
