Home > Maintenance & Modifications > Mantec Snorkel Installation Question. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20557 |
Why not bond the windscreen frame bracket on? Mine has been on a long time and no problems.
So did a previous member here years ago with no issues, it's a bit of of a faff but avoids drilling the frame. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 26th Jan 2019 10:00pm. Edited 1 time in total |
26th Jan 2019 7:10pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5771 |
The hooks of the bracket goes all the way in, so A in your pic.
No, drilling the a post won’t leak. I just drilled and tapped a thread in |
26th Jan 2019 9:29pm |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 |
When u drilled the windscreen frame did u use 5mm or 5.5mm bits. Cause mantec manual says 5mm and a YouTube video was using 5.5mm.
26th Jan 2019 9:33pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Search the site
Here is my gallery with pics and instructions https://www.defender2.net/gallery/thumbnails.php?album=26 130's have feeling's as well you know |
26th Jan 2019 10:07pm |
5mm drill bit
26th Jan 2019 11:04pm |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
I put silicon on the A Pillar bracket, and on the bracket on the air vent, if you want it water tight. |
27th Jan 2019 2:41pm |
