Home > Wheels & Tyres > Renewing tyres
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Renewing tyres
Hello all,
I will need to renew my front tyres soon, is it ok to renew just the two or will I need to renew all four to prevent damage to transmission?
I currently have the standard grabber trs and quite happy with them so would replace like for like. Tempted to upgrade all four to conti cross contact ATS but will obviously cost lots more!
Thanks
Mike
Post #752610 20th Jan 2019 3:42pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Fine to just change the fronts. Only the daft models like the Freeloader and the other plastic tripe with rubber band transmissions is that precious about tyre swaps. Permanent 4x4 vehicles usually wear the fronts out noticeably quicker. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #752664 20th Jan 2019 7:05pm
Caterham
have you considered going for a 'new' set of wheels / tyres and selling yours?
someone on here has a set, done 100 miles.
I have a set also which are cheaper but they've done more miles - I suspect the new tyres might be the better option?
could be cheaper overall?
I'll see if I can find the link for you.
https://www.defender2.net/forum/topic65074.html
Post #752671 20th Jan 2019 7:22pm
Mike c
Thanks for the responses and the link caterham but I have decided to save a bit longer and replace the four so they are all new. The conti cross contacts ats that where on the last Defenders are still available and fitted locally so will keep a standard look Cool
Mike
Post #752806 21st Jan 2019 4:07pm
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
Put your fronts on the back and you'll get a bit longer out of the set. Thumbs Up 04' 90 Td5 CSW..
Post #753001 21st Jan 2019 11:42pm
Mike c
Thanks, yes I could Thumbs Up I am hoping that I can replace in the next couple of months so not a huge issue to be honest, seeing as I do low mileage.
Post #753044 22nd Jan 2019 9:01am
discomog
I quite like the Continental Cross Contacts, I think they're a good all round AT tyre. I had BFG's on my 300Tdi and had a couple of bad experiences under braking in the wet on tarmac. Most of my off road driving is on wet grass and light mud towing a horse trailer and the CCC's definitely cope better than the BFG's. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #753053 22nd Jan 2019 9:35am
Mike c
That's good to hear, I have only read positive comments on them so must be good. I don't do much off road, occasional green lane is about it so don't need an agressive tyre.
I was quite happy with the general trs but seem to be getting hard to come by, or expensive when you do. Contis seem the natural progression and understated to look at. Thumbs Up
Post #753055 22nd Jan 2019 9:42am
