Home > Td5 > The TD5 110 fuel tank sender and pump unit peril |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 730 |
No extra charge for a rant much cheaper than professional therapy.
Does your fuel gauge work correctly now? |
22nd Jan 2019 9:02am |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
HAHA. Yeah I forgot to mention that. Yes, I think it does... it's sitting lower than it was before... and I don't think I lost a half tank of diesel in the process so I believe the new sender is spot on... apart from that its leaking slowly *pump runs and you hair an air screech every time you turn it on*
I'm not going to be using it apart from drive it to the workshop... I don't want that return feed disconnecting and spraying everything! |
22nd Jan 2019 9:07am |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
I have a 90 that reads empty when I dont think it is.... but having swapped 3 bloody fuel pumps over the years its staying in.
I've found the pump doesn't always sit bang on facing forward. Sometimes depending on the pump it's a slight a goe off. I've also found having the tank seal on the pump and then pushing it into the tank before pushing down on the pump stops the issue you describe with the pump not wanting to go in its spring loaded and pushed against the bottom of the tank back at you 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
22nd Jan 2019 9:35am |
stevec205gti Member Since: 31 Jul 2018 Location: Nr Cambridge Posts: 24 |
I don´t know if it helps, but from experience changing pumps in a Discovery 2, when you take the sender out the seal is nicely held in place at the top of the tank, and if you look at the seal in profile it looks like it should clip in place. This is a Land Rover lie designed to confuse any normal person. The seal needs to be loose around the sender and it compresses up and seals - with the seal clipped in place on the tank you can´t get it to compress and seal, or get the lock ring to go on square.
EDIT - 1 minute too slow with my typing |
24th Jan 2019 9:36am |
