Home > Maintenance & Modifications > Wipac vs Bearmach LED Lights |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
The wipac numberplate light is much better mounted without the plinth. I have one on my 90 and my parents on their 110 2002 90 Td5 Station Wagon
21st Jan 2019 10:20pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Hadn't thought of that! will just need to shorten the bolts, as without the plinth I would hazard a guess one would impede on the speaker.
Thank you for that tip though Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
21st Jan 2019 10:29pm |
Here's what they look like without the plinth
Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Jan 2019 10:33pm |
Looks good, but still not as good as my old one which I'll probably re-fit.
Just had a wild thought... I wonder how hard it would be to take a Bearmach lamp and fill it full of epoxy resin to waterproof it? Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
21st Jan 2019 11:51pm |
My BoB numberplate light resembled a terrible 90's disco after about 6 months, I threw it in the bin and fitted a wipac one - 5 years later and it's still as good as day one 2002 90 Td5 Station Wagon
22nd Jan 2019 12:02am |
Regarding the epoxy thing, it's probably better to dry the lights out fully and seal up the vent rather than filling with epoxy, you might find it alters the light output as it will act like a giant lens.... 2002 90 Td5 Station Wagon
22nd Jan 2019 12:05am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20356 |
I think my number plate light is Wipac with SMD chips, you do not want the ones with regular dome style LED's it.
Mines still on the plinth, I could surface mount it but seem little point. All my exterior lights front and rear are RDX, they've been superb right though. Naka side repeaters. Nolden headlights. No issues ever, and they weren't silly prices either. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
22nd Jan 2019 12:08am |
I had my first BoB one changed out for free. They had an issue with the first batches but the one I removed today must be 7 years old and has been on both of my Defenders. I used to have an early BoB RDX led set too, but unfortunately again due to early batches my indicator lights became whiter over time, to the point where it would fail MOT. Not sure how an LED could loose it's colour but can't fault BoB for their lights overall. That set took some serious abuse over the years! If only BoB did smoked lenses Regarding the epoxy, I could seal up the breather but I would imagine that would make things worse as the lens isn't fully sealed to the base. I'd imagine when it heats up slightly it would mist again Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
22nd Jan 2019 12:15am |
Sounds to me like a pretty naff design 2002 90 Td5 Station Wagon
22nd Jan 2019 12:24am |
If Bearmach did an IP67 rated lamp, it would be the best of them all.
Their lights are the closest match to standard, the brightest and are the least directional... As I've found out today Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
22nd Jan 2019 12:32am |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 |
After looking at several show vehicles at Peterbrough only ones dry inside the lenses where Wipac. Bought the clear led full set and never had any issue with them . 5☆ from me
22nd Jan 2019 1:00am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
I found the Wipac 95mm LED tail lights very directional. I replaced them with Perei LED tail lights with diffusers in the lens. They are far better, much less directional and with the diffused lens a bit kinder on the eye. Dun bri seem to sell them for much less than other suppliers and they cost not much more than the Wipacs they replaced.
22nd Jan 2019 12:01pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 874 |
Fitted frosted bearmach to mine last week as the factory units were dripping wet.. Didn't know the bearmachs were not fully sealed, but so far not a touch of misting in them.
Look got too and so easy to fit I surprised myself. Led number plate lamp works a treat too. |
25th Jan 2019 8:04pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Rdx lights on mine, all ok no issues at all
25th Jan 2019 8:38pm |
