Home > Puma (Tdci) > Indicators stop flashing
Phid
If indicators are left on for a while they stop flashing. Hazards work ok. For that reason I changed the indicator switch. Made no difference. I have taken the relay out and put it back in. This resulted in an improvement - ie they flash for longer before stopping.
So I suspect the relay is at fault but surprised the hazards are ok - I assume they use the same relay.
Am I right to replace relay or could it be something else?
Thanks
Post #752441 19th Jan 2019 6:07pm
Standard indicators or LED? Thumbs Up Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #752445 19th Jan 2019 6:19pm
Phid
Standard. 4pin not adjustable flasher relay
Post #752448 19th Jan 2019 6:30pm
I would remove, check and clean the earth strap on the transfer box.
If that doesn't do the trick, try a new Relay and go from there and see if that works out.
Do you have a Multimeter? If so, that may help diagnose your issues with some testing on the feeds at the indicators. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #752451 19th Jan 2019 6:33pm
Phid
Thanks
So the fact that the hazards are working ok - means they’re on a different relay?
Would a bad earth on the transfer box not affect other electrics?
Post #752453 19th Jan 2019 6:39pm
It's the same relay but more current flow with all four indicators flashing.
Earth faults can cause all manor of problems, of varying nature.
Were the pins of the relay or holder corroded at all?
I would say the Relay needs changing, it seems to not be detecting the 50% load compared to 100% load with the hazard flashing.
I'd just check the earth strap as it's free to do. Thumbs Up Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #752462 19th Jan 2019 7:05pm
Phid
Thank you
Post #752528 19th Jan 2019 11:11pm
