Home > Technical > chassis repairing 2mm to 3mm
razz
2001 Defender 90 Td5 PU Caledonian Blue
morning all , i`ve found more damage to my old bus , i tend to plate the chassis in winter and then when its warmer , let it all in nicely , i use 2mm steel every where , do you recon , where it gets damaged the most , mainly along the bottom of the chassis , and up around the curved bit , where the tub mounts pipe sticks out , i should start letting in 3mm maybe , can anyone foresee a problem with that , tar
Post #752298 19th Jan 2019 8:33am
Bongo1
3mm on the chassis i would of thought .
Post #755381 31st Jan 2019 10:47pm
