Home > In Car Electronics > Do I need to fit a relay? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
No relay needed for what you’ve stated.
16th Jan 2019 8:35pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Current draw. A relay is an electronic switch which can switch higher loads than a normal toggle switch for example. If you are using low current loads (like your led lights for example) they generally aren't required. Higher current loads which draw more than the switch can handle need a relay to handle the current so the switch doesn't melt 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
16th Jan 2019 8:43pm |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 |
Do switches come with a current load rating? The lights I am considering range between 18W and 36W. Using the 36W I would presumably need a switch with a 3A rating?? Discovery 4 HSE
Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
16th Jan 2019 8:49pm |
The current handling capacity of a switch is normally advertised when you buy. If in doubt fit a relay
As battery voltage is actually slightly higher than 12V then current draw is actually slightly less than 3 amps at 36W. A 20A rated switch such as a Carling contoura switch would cope no problem 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
16th Jan 2019 9:22pm |
olivers Member Since: 19 Jan 2012 Location: Southern Scotland Posts: 115 |
I don’t disagree with previous posters - no relay needed in your case. However, I use relays for all my worklights for a different reason: I have a separate box where the relays are located. This allows me to route the cables from the work lights (six of them, altogether) to that box, and I have thinner multi-core wires running from there to the dashboard where the switches are - much easier than having to route the actual power cables through the dashboard (and fuses, don’t forget).
Finally, if current draw is not minimal, you can also expect switches to degrade a bit over time due to corrosion. Of course a high-quality switch should deal with its rated current for a long time, but using a relay will be easier on the switch - and the relay can be changed more easily later if it should stop working. |
16th Jan 2019 9:44pm |
