Home > Puma (Tdci) > Cutting leather dash when installing double din...
cold
Has anyone done this? so I am specifically talking about the installation of the side panel that comes with the double din kits. I was wondering if there are any specifuc considerations on the way you cut, or if cutting the leather causes issues with the leather itself that remains.
My main concern was whether the leather is stretched across that panel rather than glued and so does cutting a hole cause a problem. i.e. do I need to re-glue the leather after cutting?
I hope that makes sense!
Post #751585 15th Jan 2019 11:19pm
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
While I do not know for sure, it is likely that it's glued. That s how most OEMs do it. If you do end up cutting into the dash, cut a much smaller hole first and separate the hide from the panel back to the area where you want to cut the hole for the component. This will ensure you have a lot of leather left to pull/wrap behind the panel for a clean look.
Good luck!
P
Post #751598 16th Jan 2019 6:09am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Simple don’t itll never look good relocate the switches to the cubby box I think mcma did this in his?? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #751606 16th Jan 2019 7:22am
grafty99
I personally would also avoid cutting the dash at all. There are switch holders out there which can be mounted in the cubby or I've seen a Disco 2, 6 switch holder mounted next to the steering column which looked tidy Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #751615 16th Jan 2019 8:09am
cold
Puma_MOG - thank you, that is a good idea - hadnt thought of that
pj/grafty - I had originally ruled that out but you may have prompted a rethink! thank you
Post #751630 16th Jan 2019 9:16am
