Home > Tdi > Rear light setup on 300tdi
jimmythomson
I've neglected my '96 300Tdi 110 for a while now, but finally got around to looking at the rear lights today. I've swapped out the indicators and stop/tail light for LED versions, but there's plenty of things not working the way I think they should. So first of all I'd like to clarify what people would expect the lights to do. Here's how the setup looks currently. I've added what I *think* they do:
With the side lights on, the tail lights illuminate. If I hit the brake, the tail lights dim, and the rectangular red lights light up (but barely). The two rectangular clear lights just about work as reverse lights (they're temperamental). The fog light switch doesn't appear to activate anything.
If anyone has a similar setup, could you tell me how your lights operate? Sorry, I know this is a basic question, but novice mechanic here. I just want to make sure I understand how they should operate before I start tinkering.
Thanks,
Jimmy.
Post #750986 13th Jan 2019 6:46pm
Romadog
Your fog lamps are the rectangular ones.
You seem to have shown that you have two pairs of Brake lamps.
Post #750993 13th Jan 2019 7:01pm
jimmythomson
Yeah, that was what my assumption, unfortunately the fog light switch does nothing, and those light also come on dimly when I press the break pedal Shocked
Post #750997 13th Jan 2019 7:06pm
jimmythomson
Ok, so just tested the fog light switch again and it's now illuminating the left hand side rectangular red light. Should the right hand side illuminate too? I'm guessing so.
Post #751002 13th Jan 2019 7:16pm
VVS210
Sounds like you have got an earth problem there as well. Probably worth you making up a simple test light using a bulb holder & some crocodile clips so you can test switches & connections at the lights. A meter that you can check continuity with would also be handy too.
Post #751047 13th Jan 2019 9:10pm
jimmythomson
Right-hand fog light now working after cleaning up the contacts on the light unit.
Just waiting on the arrival of another stop/tail light after I dropped one on to solid ground Big Cry
I've also got indicator issues with both indicators coming on when indicating right or left. I believe it's to do with the switch to LEDs. There's plenty of stuff online about the problem. I want to properly understand it before I make any other purchases though. If any auto-electricians can give a really clear explanation it'd be appreciated. I'm currently trying to understand the problem from looking at the electrical diagram for the indicators here: http://duud.ee/LR-manualid/300Tdi_Wiring_Diagrams.pdf#page=23
Post #751240 14th Jan 2019 6:51pm
jimmythomson
Starting to get my head around the circuit diagrams, but was hoping someone could tell me what the piece of circuitry that I've highlighted in red is:
Thanks! Thumbs Up
Post #751707 16th Jan 2019 4:24pm
dorsetsmith
highlighted in red is: logic gate in side the switch not fixable
Land Rover Defender Hazard Warning Light Switch - Yuf101490
Post #751753 16th Jan 2019 7:22pm
jimmythomson
Thanks, but are you able to elaborate on what the logic is exactly? I'm trying to fully understand everything going on in the switch, but can't find any clear electrical circuit symbols that map to what I've highlighted.
Ta.
Post #751771 16th Jan 2019 8:42pm
grafty99
I don't want to be "that guy" but you might want to swap the positions of the fog and reverse lights.
Legally, fog lights need to be a minimum of 100mm away from a brake light, they look a bit close Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #751782 16th Jan 2019 9:51pm
jimmythomson
Thanks, Grafty That's good to know, and should be an easy switch I think.
I found a reference to this in the document 'Regulation No 48' from the ECE, but interestingly couldn't see anything about it in the MOT testers manual.
I might use it as an excuse to upgrade to Bearmach's LED fog/reverse lights.
Thanks again! Thumbs Up
Post #751789 16th Jan 2019 10:20pm
grafty99
It's a strange one. Something can pass an MOT and not be road legal (go figure).
Basically an MOT just checks that everything is working as it should, not that it is necessarily legal. Rolling Eyes
As fog lights are high intensity they may dazzle and mask the brake lights so it is actually a regulation that makes sense Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #751795 16th Jan 2019 10:33pm
Martin
Site Admin
There's no electronic logic in the hazard switch - the pre-2002 switches almost pre-date the valve never mind electronics Wink
I think the gates have been used as a round-about way of showing the mechanical switching.
With the switch in the normal (off) position, the ignition feed (pin 8, GREEN) is connected to the output to the flasher relay (pin 5, LIGHT GREEN).
Nothing happens unless the ignition is on and the indicator switch connects one side or the other to the output from the flasher relay. Then you get indicators that side.
With the switch in the on position (hazards on), the ignition to flasher link is cut (bottom "relay"). Now:
Permanent 12V (pin 7, PURPLE) is connected to flasher relay (pin 5, LIGHT GREEN).
Feed from flasher relay (pin 2, LIGHT GREEN WITH BROWN) is connected to the left indicators (pin 3, GREEN WITH RED) and right indicators (pin 4, GREEN WITH WHITE) and the warning lamp (pin 1, BLACK WITH RED).
So the flasher relay is fed power, and both indicator feeds (plus hazard warning light) are connected to the output from the flasher relay.
Hey presto - hazards!
The real internal diagram is like this:
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #751808 17th Jan 2019 12:13am
jimmythomson
Thanks, Martin. That's really useful stuff. I think I've now got my head around it all.
I'll report back with an update once I've had a chance to try a few fixes.
Thanks again!
Post #751810 17th Jan 2019 12:47am
dorsetsmith
Past and copy
Post #751829 17th Jan 2019 9:04am
