Home > Puma (Tdci) > Replacing A/C expansion valve without removing the dash?
dantastic
I need to change the expansion valve on the AC and I was told it's a heater box out job. I can see the valve from the engine bay though and looking at it I think it's possible to swap it out without taking out the dash. I'm sure it's tight but surely less hassle than removing the dash.
Anyone tried this?
Post #749703 7th Jan 2019 9:50am
Bluest
I can't really advise on the valve, but would say that the if you end up having to take the dash out it's not that difficult. Can probably do it in an hour. There is a step by step in the factory workshop manual that can be downloaded from this forum. Just need to be methodical. 2007 110 TDCi Station Wagon XS
Post #749757 7th Jan 2019 2:15pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Practically, yes you can once the ecu is out of the way, however it’s tight.
The downside is when you fit another one back is making sure you have no leaks, again it’s tight.
Removing the dash is a 30 min job at max and you’ll know the new part is fitted correctly Thumbs Up
Post #749774 7th Jan 2019 4:56pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Honestly, I'd remove the dash. For 45mins easy work you'll save yourself 45mins or more of hassle and cursing. Also gives you the opportunity to inspect the other components whilst it's out and, if you're up for it, I'd split the heater box and clean it out. Surprisingly dirty they get! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #749856 8th Jan 2019 12:00am
lohr500
If you do take the dash out, it would be worth checking the wiper wheelboxes for wear as these seem to be problematic.
With the dash out it is a quick job to change them.
Post #749871 8th Jan 2019 7:49am
dantastic
Hmm, I've had the dash out before and I thought it was a pig of a job. I might try from the engine bay first
Post #749875 8th Jan 2019 8:09am
