Home > Technical > landrover puma 2.2 fuses
dcpallets
is there a fuse that works horn when door is left ajar, to make it sound. If so where is it located please thanks
Post #749525 6th Jan 2019 9:32am
dorsetsmith
No fuse form that but
Alarm mislock then door is left ajar, to make it sound
Alarm (mislock) can be switch off, alarm unit will need to be reprogrammed
Post #749530 6th Jan 2019 10:19am
dcpallets
i think as prev i wrote about right hand indicator does not flash either when locking and unlocking. could all be linked ?
Post #749547 6th Jan 2019 12:17pm
dorsetsmith
one fuse for alarm and indicator output right and left hand
the horn and sounder unit not fuse on the same cct
Post #749561 6th Jan 2019 2:10pm
dcpallets
is it possible to remove alarm module?. Without screwing up anything?. to take alook inside to see if there is a dry joint for non working indicator ,
Post #749633 6th Jan 2019 7:52pm
dorsetsmith
I have remover alarm unit from TD5 and had them repaired and refitted them
Post #749637 6th Jan 2019 8:02pm
