Home > Off Topic > Car Port Project
Bluest
Car Port Project
I've got a bit of a project on the go building a carport to keep the 110 out of the rain. It's easier to do that than find all the leaks in the car!
The frame is all up now and I'd like to get the roof on. My plan was OSB covered with roofing felt then some nice felt shingles over that. Trouble is, I'm restricted to weekends and with the crap weather and limited daylight I'm unlikely to be able to get the OSB on and covered with felt in a day, so there is a good chance it might need to spend a week or two exposed to rain/snow etc.
Is it ok to leave OSB out in the weather? Should I treat it or use something else, or just give up and wait until summer? 2007 110 TDCi Station Wagon XS
Post #748925 3rd Jan 2019 4:35pm
Rashers
When I built mine I got a large tarpaulin from Screwfix and screwed it down with battens.
OSB will take a bit of weather and moisture, but I would rather have it covered.
Post #748928 3rd Jan 2019 4:41pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
If your framework is all in place then you'll be surprised how much you can get done in the day. There are many different grades of osb and moisture resistant boards are better. Have you considered breathable roofing felt under your shingles? Perhaps consider using fibreglass too.
Post #748932 3rd Jan 2019 4:50pm
landy andy
Easy to board, and felt in a day. Doesn’t take long once you get started.
Post #748936 3rd Jan 2019 5:01pm
Bluest
I'm not really an expert on roofing, so I'm just making it up as I go really. I've only ever done a couple of sheds before. Not familiar with fibreglass Vs felt. All I know is I want to end up with some nice looking felt shingles. I'd like it to last as well.
I could cover the OSB with tarp temporarily if I need to,. 2007 110 TDCi Station Wagon XS
Post #748937 3rd Jan 2019 5:03pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Rather than leaving the OSB exposed pre-felt I'd get a roll of 1000 gauge PVC damp proof membrane and use it to cover the work-in-progress. Or use a roofing sheet that doesn't need felt to resist the weather.
Post #748938 3rd Jan 2019 5:04pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
It'll be fine for a car port for a week or 2 exposed Thumbs Up
I use it alot and it's tough stuff
Post #748939 3rd Jan 2019 5:14pm
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
^^^ plus one, if it has good pitch, ie water will not pool, then up to a month at max.
It's best to felt it properly asap, patterned tarps will mean holes, water will get in, and get trapped causing more problems.
Get it up and covered as quick as you can, but just felt it when it is bone dry.
Only my 2 pence worth. 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #749333 5th Jan 2019 10:33am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
It's a while since I did any roofing work, the last time I had to abandon the felting due to snow. I did have the foresight to use OSB3 which is moisture resistant. Two tip's, try finding OSB3 that is either tonged and grooved or with a half lap joint and the boards normally have a face or smoother side which the felt should be laid on this will prevent the board cutting into the felt. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #749338 5th Jan 2019 10:58am
Balvaig
I have used Onduline corrugated bitumen sheet. Easy to cut and fix and can be installed in any weather.
Available from most builders merchants or online. Bit more expensive than felt but lasts much longer.
Post #749354 5th Jan 2019 12:31pm
JOW240725
Felt is pretty old fashioned these days, much better materials available now, speak to your builders merchant.
I second onduline, we use extensively on the farm. I quite like the look and if well supported underneath with a decent pitch will last year's. The other option is box profile tin, in various colours, to save boarding and felting.
Good luck, don't forget photos Thumbs Up James
Instagram @suffolk_rovers
Post #749385 5th Jan 2019 3:53pm
Bluest
Thanks all, I'll do some research into the alternatives to felt. It does need to be an attractive finish, rather than purely function, as we will be looking down on it from the garden. Hence the leaning towards shingles 2007 110 TDCi Station Wagon XS
Post #749419 5th Jan 2019 6:00pm
JOW240725
Cedar shingles looks great Whistle or get Clayton to that it!! Shocked Razz James
Post #749420 5th Jan 2019 6:08pm
JOW240725
Damn this new mobile changing text all the time... thatch! Thatch it. James
Post #749421 5th Jan 2019 6:09pm
landy andy
Agree with above cedar shingles look and smell great. Thumbs Up Thumbs Up
If your roof it at a steep enough gradient then leaving un, or part uncovered won’t be a problem.
Post #749432 5th Jan 2019 6:38pm
