Home > Td5 > 100K service / headgasket / Preventative maintenance. |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 822 |
So i'm creeping up to 100K on the clock, and having a look around i've had a look on the web and haven't come up with much, other than treat it as an intensive service...
But having a look on the Alive facebook page they recommend changing head gaskets at 100K to prevent Head warp. Thoughts? if its done 98K so far so good then is it better not to interfere or perhaps better to intervene? Are there any other items of preventative replacement ect? aside from tracking and turbo spool down I've had no problems. (touch-wood) cheers I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
30th Dec 2018 9:26pm |
How does changing the head gasket prevent head warp? Are they suggesting a different gasket? Darren
30th Dec 2018 9:38pm |
then there was a load of outcry. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
30th Dec 2018 9:45pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
I had a overhaul done at 112k.
Had coolant leak and oil leak so had head off and checked, new gasket (all genuine parts) seals, injectors etc, and fuel pressure regulator. New radiator, intercooler, all hoses replaced (LR parts), new tyres, brake pads, discs, calipers, brake hoses and some other bits and bobs. Some of this did not need replacing but decided to do preventative overhaul |
31st Dec 2018 8:08am |
Hmm, ok. They've got a point about them having more experience than most but they also qualify the recommendation by saying that it depends on usage and state of tune. So the question then becomes one of how do you use your LR and is it heavily tuned? If it's standard and spends most of its' time pootling about then it's probably overkill but if you're planning on dune bashing in Morocco or similar and have all of the usual tuning toys then it'd be a worthwhile precaution. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Dec 2018 8:12am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2780 |
But l wouldn’t take the head off if there’s nothing wrong with it? They don’t all fail, although the earlier pre-2001 10p engine is worse in that respect.
31st Dec 2018 10:00am |
Yes i believe the 10P had something wrong with the dowels.
Just when i had the ST i had an engine runaway in 3rd pulling onto the motorway and had to get the engine rebuilt, turns out there was a service item that wasn't attended to by main dealer or something... I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
31st Dec 2018 11:14am |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 |
I would replace the crankshaft damper, mine had the "chirp" when you turned it off at 90k so replaced it and the rubber was in poor condition - perished etc.
I have also just replaced one on a 04 Disco 2 with 110k on the clock, sheared off luckily when they were slowing down for a junction and didn't damage anything else. When I asked if it had a "chirp" they said it had for a while.. its gone now its had a new damper. Click image to enlarge |
31st Dec 2018 3:13pm |
Mine’s chirped when you turn off the engine for years. I mentioned the harmonic damper to my local LR specialist but they chuffed it off.
The aux belt can chirp when you stop the engine. A spray of silicone will temporarily stop it and let you know if it’s the belt, or the damper. I am guessing it’s the belt on mine, although l’ve changed it twice in the last 4 years. |
31st Dec 2018 6:55pm |
I don’t think anyone really knows the cause of the “chirp” all I know is that every damper I have replaced has been shot and after the “Chirp” has disappeared never to return so they are some how linked?
I always assumed it was the extra give in the damper rubber and it did it as it returned back as the centre piece stopped with the engine but the outer has enough give to twist a little - maybe the chirp is it rubbing on the stationary belt as it flex’s back to its resting position so a spray of lube would stop it regardless. My chirp survived a belt, tensioner and idler change I have two old dampers in the garage I think, if so I’ll take some pics of the rubber after ~100k / 14 years. |
31st Dec 2018 7:24pm |
Yes that would be good as my 110 is 14 years old and on 106,000.
Is replacing the damper a DIY job? What is involved? |
31st Dec 2018 9:49pm |
It seems my other half has scrapped mine Here is one that was from a 53 plate with 90k on the clock, it's not as bad as the one I wanted to show you, but you can see where the rubber is degrading and has what looks like loads of small tears in it.
Easy job, the problem for most would be the 460Nm that the pulley bolt is done up to requires a rather large torque wrench otherwise remove fan, aux belt, and then it's one big bolt. I drilled a length of bar and used two of the TV damper bolts to hold it to undo / tighten it. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Last edited by TJH1985 on 3rd Jan 2019 12:58pm. Edited 1 time in total |
2nd Jan 2019 2:38pm |
Thank you for the photos. I think it’s time to change mine, l’ll get the removal tool.
3rd Jan 2019 12:26pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
15p engines can have plastic head locating dowels too (as mine did)
My Defender has been heavily tuned for nearly 100k miles, the only reason I had a problem was because of the plastic dowels. I replaced the head because the head had been floating (dowels broken) and burred around the cylinders. Td5 heads can only take a VERY light skim, so to be sure I just replaced the head. I had symptoms for quite a while before I eventually got round to doing anything about it. I would suggest leaving it alone until you have symptoms. If it ain't broke don't fix it 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
3rd Jan 2019 2:12pm |
