![]() | Home > Technical > LED light kit issue |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
I assume you have tried wires both ways onto new light fitting?
Filament lights are not polarity sensitive.
LEDs are polarity sensitive. You need to swop the two wires on the rear indicator plug to get it to work. Brendan |
Timbo66 Member Since: 14 Oct 2018 Location: Leicester Posts: 37 ![]() ![]() ![]() |
It is plug and play with fitting plugs to fit the original socket.
Do you think this could still be t h e issue?? |
Yes I do.
If you have a decent multimeter, set it to a range like 20 volts DC. Carefully note the orientation of the socket on both rear indicator and measure the voltage on indicating. Chances are one will show a negative voltage and the other a positive voltage. Brendan |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 ![]() ![]() ![]() |
+1 for polarity. Try swapping the wires within the connector
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Thank you all for the responses. I'm guessing that as the LED is pre-wired it must be within the wiring on the vehicle.
I will give it a try when I get home tonight and report back!! |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
If you have a couple bits of wire to make two jumper cables it would be easy to test the theory before committing to cutting plugs off. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
You can check this by comparing the wiring on the other side of the vehicle as the wires are colour coded
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
There is no need to cut plugs off! It us quite easy to remove terminals from Econoseal connectors without damage!
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thank you all, some really useful info.
Much appreciated. |
Success!!
Swapped the cables over and we have a flash. Thanks again to all that responded. Tim. |
Great news.
Mcmuffin Member Since: 01 Apr 2014 Location: Antwerp city Posts: 38 ![]() ![]() ![]() |
problem solved ! But still 1-0 for the factory guys
They will always win ,
