Home > Technical > Rear shock washer orientation
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
So I've just started upgrading my shocks to bilstein to go with my softer springs. All to aid a better ride and better handling.
When I removed the original rear shocks the washers were such so that the dome was pressing agains the bushes. I've fitted the bilsteins with the washers the same way but I just wanted to check with everyone that that's right. The bilstein instruction leaflet shows them all different ways according to your figment so I was 100% sure.
Thanks
Original as I took them off...
I've fitted them the same as the LR shocks
Looking gooooood!
Post #748075 30th Dec 2018 4:29pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Yes you're right, the domed surface goes against the rubber bush, otherwise it 'cups" the bushes against the mount and seriously restricts the flex, end result, the top of the shocker canister flexes instead where the bolt is welded on which breaks off after a while. (Don't ask me how I know Embarassed )
Post #748106 30th Dec 2018 7:17pm
LandymanStefan
Great! Just waiting for my new shock turrets before I can get the fronts in.
Post #748122 30th Dec 2018 8:40pm
williamthedog
Is that blood on the new shock in the 2nd picture? Knuckle rash today perhaps?
Post #748138 30th Dec 2018 9:29pm
LandymanStefan
Haha! No its the waxy anti corrosion stuff i put on my nuts and bolts. Ardrox AV30 if you want to know exacty what it is. Must have caught it with the brush, just havent wiped it off yet. Thumbs Up
Post #748222 31st Dec 2018 10:54am
Roy5695
I also did this job yesterday. Bit of a mind boggle getting all the cups the right way around. The fitting instructions were as much use as my 1 year old.
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #748260 31st Dec 2018 2:38pm
The top mount washer on the rear has the curved side towards the chassis and the flat side out toward the nut.
Thumbs Up KEEP CALM AND Drill ON
šŸ‡¬šŸ‡§šŸ“󠁧󠁢󠁄󠁮󠁧ó æšŸ“󠁧󠁢󠁷󠁬󠁳ó æšŸ“󠁧󠁢󠁳󠁣󠁓ó æšŸ‡®šŸ‡ŖšŸ‡ŗšŸ‡øā›½ļøšŸ›¢ļøāš™ļøšŸ§°šŸ’Ŗ
Post #748290 31st Dec 2018 4:44pm
williamthedog
Didn't you contemplate changing the turrets when you changed everything over? The top is a lovely water trap on the standard turrets. When I done mine I fitted D44 h/d turrets. No rust traps.
Post #748357 31st Dec 2018 8:41pm
Roy5695
I did contemplate it yes. I just thought Iā€™d assess the condition of the standards and for 7 years old living in Cornwall they were pretty good. Will change them at some point. Probably when I upgrade the springs. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #748410 31st Dec 2018 11:58pm
I have D44 turrets too, in Matt black. They are very good combined with the HD turret rings.
As mentioned above worth thinking about at a later date. Thumbs Up KEEP CALM AND Drill ON
Post #748415 1st Jan 2019 12:29am
