![]() | Home > Maintenance & Modifications > Screwed up whilst screwing in, now can't screw out! |
Mole grips on the back, get the screw out, retighten existing rivnut, halfords have cheap riv nut tools that will do. Original Member Pie n Pea Club.
110 HCPU Tipper |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 ![]() ![]() ![]() |
Cheers Willy.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1852 ![]() ![]() ![]() |
Hold the back of the rivnut with pliers - not too tight or you risk distorting it, unsrew bolt, gently retap with 2nd taper tap, then either reset with tool, or 3 flat washers and a new bolt with grease, hold back of rivnut and reset with spanner.
Good luck! Keith |
Yes, don't squeeze the rivnut too tight or it will clamp onto the bolt even tighter. Steve.
