Home > Td5 > Defender Door Cards
Moxy
Scotland 1999 Defender 90 2.5 TD HT Baltic Blue
Defender Door Cards
On my return home I have a few jobs to do on the doors but my first obstacle is removing the door cards.
I read a few horror stories about parts breaking or not going back on properly.
Does anyone have an idiots guid from start to finish from removing the window winder to the door lock button on removing the card and then reinstalling it as good as new ?
I’m looking at sound proofing the doors and fitting hinge guards.
Many thanks.
Post #746697 21st Dec 2018 5:57am
lightning
The main problem is popping off the fasteners without half of the yellow bases on the door card breaking off.
It’s almost impossible to prevent it from happening, but there is a repair.
What you do is cut off the remaining stud from the yellow part on the door card, so it’s flat. Then drill a small hole in the centre and screw a small flat head screw in, leaving the head about 5mm proud. After that you can refit the white fastener and you are back in business.
You need to select a screw with a head that fits the white fastener, and is not too long. It sounds complicated but takes about a minute to do one broken fastener.
Post #746805 21st Dec 2018 9:36pm
I took all mine off in the past and never broke anything, you really need a trim tool though like one used for popping fir trees.
Don’t forget to also protect the paint.
Using trim tool(s) allows you to use just the right amount of pressure.
IIRC you pop out all of the ones around the outside, then lift the whole card upwards off remaining clips. Not being over forceful and taking time is the answer.
Obviously taking off door handle and other bits come first WeWillWin🇬🇧🇺🇸
Post #746806 21st Dec 2018 9:43pm
lightning
I used the correct tool last time but three still broke.
After repair they never break again.
Post #746844 21st Dec 2018 11:31pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
All you need is this. Philips screw driver (to remove all the door crad screws) door panel tool (to pop all the side and bottom tabs) and these tiny little screws (and no drilling is needed) if you break a tab.
As said just file or cut down the nub till its flat and then screw in the tiny screw into the centre of the yellow plastic and Bob’s your uncle. Thumbs Up
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #747059 23rd Dec 2018 4:42pm
lightning
Yes you can blodger the screw in to the broken fastener, but much better to drill a small pilot hole first.
Post #747065 23rd Dec 2018 6:00pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
If you don't drill a pilot hole and try to force screw it in, it can result in the yellow piece cracking. ask me how i know. The defender has migrated, leaving the owner behind.
Post #747291 25th Dec 2018 1:18pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
A few pics that may assist. Tap the lock button up with a small length of wood. Tap the corner pins in with a small nail. Repair the any broken yellow heads with a small stainless screw after predrilling 1.5mm drill.
Post #747333 26th Dec 2018 1:35am
I always lubricate the plastic pins with a smear of Vaseline before refitting the door card, this makes them less likely to break the next time you have to remove them.
Post #747350 26th Dec 2018 10:19am
Mo Murphy
That screw tip is a good one, thanks for posting Thumbs Up
50 Shades of Pennine Grey
Post #747512 27th Dec 2018 11:01am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Some great info here, thanks Gents. And good luck Moxy! Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #747515 27th Dec 2018 11:07am
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
I see your repairs, but i have a problem with the fasteners not holding in the white rings when i press the door card on.
All new fasteners, some with the screw fix to hold them to the door. I also installed the foam pc where the window wiper was.
How do i get them to hold and not pop open? Can't leave well enough alone
Post #902516 11th May 2021 7:37am
4RF RDS
Naf, likely the white plastic things are worn out, pick up some new ones and try that. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #902593 11th May 2021 6:14pm
Naf
They are all new. Can't leave well enough alone
Post #902644 12th May 2021 8:27am
