Home > Puma (Tdci) > Puma revs to 1000rpm on its own? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8032 |
Idle Jack keeps it at 1100rpm in 1st and rev in low. Maybe it's rewired wrong and thinks it's in low? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Dec 2018 5:58pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 539 |
+1 that sounds exactly like when the TB is in low range... Check your low/high switch (IGM500011), connector and wiring (for the record, in low range the circuit is closed) “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
21st Dec 2018 7:53am |
carl_puma90 Member Since: 05 Jul 2018 Location: valletta Posts: 2 |
FIXED! the high/low switch was disconnected closed circuit so it was thinking it is in low range.
Thanks for your help!! |
23rd Dec 2018 10:00am |
