Home > Td5 > Defender MPG |
Norton Member Since: 10 Sep 2018 Location: Buckinghamshire Posts: 28 |
Around low 20's at motorway speeds. High 20's on A roads.
16th Dec 2018 1:27pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Having done several runs to and from pompy averageing 170ish miles each way I’m doing the trip in about a 1/3 of a tank so I must be close to 30 mpg in Buggsy, makes no real difference if loaded or not and the whacking great roof rack doesn’t seem to effect it, I normally sit around 55-60 and am driving in stupid o’clock hours. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
16th Dec 2018 5:06pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
I put in £40 per week and do on average 800 miles a month, so £40 gets me 200 miles!!!!
Any good??? |
16th Dec 2018 7:21pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
I do mainly short trips and last time I calculated I was getting about 27mpg running STT pro tyres
20th Dec 2018 7:37pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
Caterham has some high claims and I have tried to match them which I can for short periods of time, but it needs to be in the 1500-1750 RPM range and between 30 and 50mph, you will be surprised what can be achieved if you try to drive in this range.
Unfortunately I cant do it for long as I get fed up quickly. notably both myself and Caterham have 2011 2.4s DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
21st Dec 2018 10:18am |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
I think ill start a tally of what im spending and how many miles im getting - I do reset the counter each time I fill up. And usually get between 230-280 a tank.. Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
21st Dec 2018 1:49pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5872 |
I get around 300 to a full tank in my 110 (but always find the needle for the fuel gauge drop quicker from half to 1/4 than full to half) 1999 Defender TD5 110
21st Dec 2018 2:33pm |
The needle doesn't seem to move from full till after the first 60 odd miles in mine.
21st Dec 2018 2:42pm |
Mine is the same but its half to 1/4 that drops really quick compared to the miles covered 1999 Defender TD5 110
21st Dec 2018 2:43pm |
Agreed - I fill right to the brim! and get nearly 60 miles from past the full mark to the full mark, but then between full and 1/4 its like 180 miles... Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
21st Dec 2018 2:49pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
The fuel gauge on the Td5's are very non-linear, I might get 100 miles+ from the first quarter then only about 50 or less from the last. My previous one was just the same, not much more than a rough guide really, better than nothing though
On a high note, I was away over the weekend and came back from Canterbury, plus a bit of running around and got 350 miles from a full tank (49.3 litres to the brim,) of Morrisons finest regular diesel, = 32.26 mpg |
21st Dec 2018 4:05pm |
I never let mine go past half way as I've run out before when guage was on the last quarter line.
21st Dec 2018 5:53pm |
Nice! That's good going that. I'm going to make a conscious effort to start recording my fuel stats. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
22nd Dec 2018 11:02pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2898 |
I have been firmly in the red at the bottom of the gauge and still running.
2005 TD5 110 But l normally fill up when it gets to half full, as it definitely rides a bit better with the extra weight. Click image to enlarge |
22nd Dec 2018 11:28pm |
