Home > Td5 > Swivel housing,steering problem |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Make sure the CV joint and halfshaft are pulled fully into the stub axle (outwards)
Steve 02' 110 TD5 Double Cab Rebuild Thread |
13th Dec 2018 6:40am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 952 |
Also make sure you have the top and bottom bearing races in correctly. The races look the same however are very different and can easily be put in the wrong end. You can assemble it as if normal but it will not function properly. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
13th Dec 2018 3:16pm |
kfb118 Member Since: 27 Jul 2017 Location: derry Posts: 8 |
Many thanks for your replies, I bolted the stub axle back on and pulled the cv joint fully into
the stub axle as Steve suggested and the whole thing moved smoothly, lock to lock. I would not have thought of making that adjustment untill I was putting on the cir clip and spacers after fitting the drive flange. Everyday is a school day as they say Many thanks again Kenny |
13th Dec 2018 8:44pm |
