Home > Technical > How concentric should the wheel rim be to the hub?
Co1
I’m trying to locate a judder though the steering. When I rotate my wheels they are pretty much perfect horizontally, less than 0.3mm across 180 degrees. However there is roughly 1mm difference between the distance from the hub of the wheel to the rim (not tyre). Is this enough to make a difference or would the tyre iron this out? I feel like it wouldn’t be noticeable, what does the general consensus feel?
Post #745548 13th Dec 2018 5:29pm
rallysteve
Steel or alloy amd which piece of the rim are you measuring? 02' 110 TD5 Double Cab Rebuild Thread
Post #745556 13th Dec 2018 5:46pm
Co1
Alloy. I’m measuring the bottom edge of the rim for the vertical and the outside edge for horizontal.
Thanks
Col
Post #745571 13th Dec 2018 6:25pm
