Home > Maintenance & Modifications > Turbo Manifold Gasket Leak - Puma TDCI
SkyFallSilver
Kuwait
Hello,
My Defender 90 has every now and then an exhaust leak from the turbo manifold and I have replaced it several times with Nakatanenga gasket, I've retightened it now and it still whistles slightly.
What would you recommend I do? I am on my second gasket now and I predominately use my Defender 90 as my daily driver.
Thank you in advance 2016 Defender 90 Adventure Edition
Post #744918 10th Dec 2018 4:02am
landy andy
You could get the two mating surfaces refaced, but in the end it’s just a poor quality casting. My old one.
Post #744934 10th Dec 2018 8:30am
SkyFallSilver
Kuwait
Thank you,
The turbo manifold is fine as it looks. 2016 Defender 90 Adventure Edition
Post #745100 11th Dec 2018 6:21am
LR90XS2011
No personal experience on this engine but on others
Both surfaces need to be clean, flat or slightly convex, needs to be reassembled with everything cold, the exhaust system needs to be under no bias when fitted, do up the nuts loosely and tighten up a bit at a time, until all of them are at the correct torque. After you have run it upto temperature and it has cooled down re torque the nuts. DEFENDER 90 TDCI XS,
Post #745102 11th Dec 2018 6:53am
AndrewS
This may be of some interest
https://www.defender2.net/forum/topic457.html?highlight=turbo 130's have feeling's as well you know Smile
Post #745106 11th Dec 2018 7:46am
SkyFallSilver
Kuwait
Thank you for your insight, I will give it another try. 2016 Defender 90 Adventure Edition
Post #745433 13th Dec 2018 4:06am
It is reasonably common for the manifold-to-head gasket to do the same thing, so it might be worth checking that joint too.
Post #745446 13th Dec 2018 7:30am
SkyFallSilver
Kuwait
Thank you I will look into that as well. 2016 Defender 90 Adventure Edition
Post #745747 14th Dec 2018 9:22pm
