Home > Td5 > Td5 Wiper motor park switch replacement (with aircon)
Journal Photo
United Kingdom 2006 Defender 90 Td5 CSW Indus Silver
TD5 Defender wiper motor return switch replacement on a defender with an aircon fitted, a little advice please.
Post #745077 10th Dec 2018 10:32pm
landy andy
Did mine years ago, and it was so easy I can’t remember much about it. Think I managed with just the padding removed from the dash top.
Post #745082 10th Dec 2018 10:53pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Agree with Andy, it's a very easy job. Did mine a few months ago, expecting it to be a pig. Simply removed the dash top and there was just enough room to get to the park switch.
Tony
Post #745194 11th Dec 2018 4:52pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Just undo the four side screws on ether side of the dash and remove them, the ones holding the AC plenum. Remove the cetre screw or at least back it out almost to removed to take the weight of the plenum. Let it rest where it it. Gently pull the plenum down a bit, this will allow you access to the wiper dash cover screws. Remove them, change the switch. Now reverse the process. Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #745199 11th Dec 2018 5:22pm
Journal Photo
may I thank you all for all your helpful comments on this, ready steady spit on my hands and get in there. Bow down
Post #746369 18th Dec 2018 11:20pm
