Home > My Defender > My USW
Page 28 of 37 <123 ... 272829 ... 353637>
22900013A
Yes. Might take me a while to trust it again though... 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #726347 30th Aug 2018 7:56pm
22900013A
Hit 80,000 last night on the way to Oxford.
Still not feeling very confident with my clutch/gearbox, doesn't seem as nice as the 35,000 miler I'm driving at work... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #728659 12th Sep 2018 6:16pm
L110CDL
Does it feel better or worse now, than when you first got the landy ? 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #729331 16th Sep 2018 7:05pm
22900013A
Worse I would say. Sometimes doesn't drop into gear, sometimes feels a bit notchy.
Oh and the reversing lamp has packed up. But it isn't the bulb. Sad 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #729348 16th Sep 2018 7:31pm
L110CDL
Doesn't sound to promising if it's worse Sad Have you mentioned it to your mechanic about it not being so good as before Question Sounds like a new reverse switch then ( i think that's what it is called, the name has slipped my mind ) Rolling Eyes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #729351 16th Sep 2018 7:38pm
22900013A
Oh it's much better than before the clutch failed, I think it just doesn't feel as nice as my 2.2 works truck which has done less than half the mileage.
Reverse lamp might have to wait until it's next service, along with the rattling exhaust. Is my exasperation with landrovers showing? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #729387 16th Sep 2018 8:36pm
L110CDL
It's just showing a little bit Laughing
Cant be to bad then if it's better than before Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #729407 16th Sep 2018 9:30pm
22900013A
Its seven years old and starting to show some signs of age I guess. How good do we expect an 80,000+ mile gearbox to be anyway? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #729564 17th Sep 2018 5:19pm
At 80k miles I'd expect a modern gearbox to be at its peak, properly run in and just about as good as it gets. My 230k gearbox is perfect, although the same cannot be said of the transfer box (number 2) which is now whining much like number 1 did when I removed it at 150k miles.
Post #729568 17th Sep 2018 5:30pm
L110CDL
Hi blackwolf, is your gearbox the original one or have you put in a recon one that has done this sort of mileage, many thanks. 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #729610 17th Sep 2018 7:35pm
Engine, gearbox, and output adaptor shaft are original. I'm on the second transfer box, fifth or sixth clutch (I've lost count)!
Post #729624 17th Sep 2018 8:01pm
L110CDL
Thanks blackwolf Thumbs Up
I'm only on the original engine, turbo so far, you have fared better with the gearboxes than me, i'm on my second transfer box as well Smile 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #729653 17th Sep 2018 9:03pm
22900013A
Aside from a recent service I have not really done anything with my 110 recently. Now just over 82,000 miles and the clutch now feels normal so guess it just required some bedding in. I do have it booked in for fitting heated mirrors and spotlamps as I am heading into Europe in the winter and I'm sick of not being able to see very much around here at night. Not a big fan of modifications but these do make sense... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #744760 9th Dec 2018 8:27am
L110CDL
Know what you mean with the heated mirrors and makes a lot of sense to have them fitted Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #745393 12th Dec 2018 9:31pm
22900013A
So the mirrors and lamps went on. I told the garage roughly what I wanted and was pleasantly surprised with the result, looks good and VERY bright!
I then went to Germany which was pretty uneventful aside from my dipped beam backing up which I had to get repaired at Kassel...
 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #751747 16th Jan 2019 6:14pm
