Home > Puma (Tdci) > Instrument cluster removal
redline
Switzerland
I'm having to remove the instrument cluster, to access the Lucas 10AS immobilizer.
Looking through the workshop manual, the final step on re-assembly is:
6. Using the approved Land Rover diagnostic equipment, configure the instrument cluster.
Does this mean that the instruments must be reconfigured after removal??
What happens if it isn't?
Post #744674 8th Dec 2018 4:40pm
WindyJ
If fitting a new one yes, but not if fitting same cluster back in.
Post #744681 8th Dec 2018 4:57pm
redline
Switzerland
Thanks Windy - makes sense!
Was a bit worried as I'd read on a S.African or Australian forum, that the dealer needed to re-program following a remove and re-fit, but seemed a bit odd...
Post #744689 8th Dec 2018 5:56pm
I've removed mine and refitted it without problems on more than one occasion.
Post #744716 8th Dec 2018 7:39pm
redline
Switzerland
Removed the cluster this evening, and was surprised that the immobiliser is actually not behind the instruments.... I'm assuming that I have to remove the whole dash Rolling Eyes
Anyone know how to release the connector? It looks like the the black bit is a retaining clip that needs to be lifted, and pivots around the hinge line. Its quite stiff through and a bit nervous about forcing it...
Post #744840 9th Dec 2018 6:58pm
redline
Switzerland
Also, any idea where I can get replacement retainers for the instrument cluster fixing screws?
Post #744843 9th Dec 2018 7:04pm
WindyJ
Looks like the black thing comes up as arrowed yes. Cant remember tbh other than it was stiff. As far as those little blue things go, i ended up cutting a slot in and then gluing in some large wall plugs. Worked a treat!
Post #744850 9th Dec 2018 7:28pm
redline
Switzerland
Thanks Windy - excellent idea with the wall plugs! May copy that Very Happy
Post #744856 9th Dec 2018 7:52pm
NickMc
The 10AS is in behind the speaker drivers side.
Post #744883 9th Dec 2018 9:28pm
redline
Switzerland
Excellent - Many thanks McNick! Was fearing a dash removal job...
Post #744888 9th Dec 2018 9:52pm
ericvv
Not possible to order separately from LR. This blue clip has no LR part number.
But you can order it from BMW as they use it in their Mini. Google BMW part number 07131472727. Sometimes you also find it on eBay.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #744892 9th Dec 2018 10:02pm
redline
Switzerland
Merci Eric! I won't ask how you know this from your lovely SVX...!
Post #744896 9th Dec 2018 10:09pm
Martin
Site Admin
See this thread from the other day https://www.defender2.net/forum/topic64947.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #744902 9th Dec 2018 10:40pm
