Home > Td5 > TD5 heater not working
Greeny
With winter well and truly here, I thought it was about time that I fixed my heater. It suddenly stopped working in the respect that when I pull the toggle to engage the heater on the left hand side of the dash, it doesnt work at all. Nothing is coming out of the heater vents below the windscreen.
Any ideas of how to fix this or what the problem is?
Thanks in advance! Instagram - @Land_Rover_Defender
Post #744477 7th Dec 2018 12:19pm
dorsetsmith
fuse 13 (20 amp) ok in the passenger fuse box Question
Have you voltage at fuse 13 Question
Toggle to engage the heater on the left hand side of the dash, this in side your dash
(red arrow ) black ground wire make shore connected
If the fuse has blow check fan blade and motor will mover and not seized Exclamation
Post #744480 7th Dec 2018 12:41pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
What Dorsetsmith said about covers it all. It is truly a very simple system and super easy to trace problems. Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #744523 7th Dec 2018 5:44pm
Greeny
Brilliant, thank you!
I will let you know how I get on, cheers Very Happy Instagram - @Land_Rover_Defender
Post #744604 7th Dec 2018 11:35pm
