Home > Maintenance & Modifications > Driver's Door - Card Removal
Frunch
United Kingdom 2008 Defender 90 Puma 2.2 CSW Chawton White
Good Evening Membership,
I need to remove the door card on the driver's side door to access the wiring to the window operating motor. (Broken wire inside the flexible rubber tubing between the door and the door frame - but I need to expose the wiring inside the door to repair it.)
I have a "card-popper" tool. However, all of the information I have found so far about the card removal refers to earlier model LRs.
Other than going carefully to avoid breaking the plastic fixings are there any hidden pitfalls anyone has found before I start the removal?
If I need to replace the plastic fasteners will the MXC1800 type fit?
All advice gratefully received.
Regards.
Post #744241 5th Dec 2018 7:04pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
hello Frunch, what age is your defender, i have a few pics and tips for a 2004 including those little xmas tree fixings and the small head they sit on which broke on my cards. Happy to upload if they would be of use.
Post #744266 5th Dec 2018 9:03pm
Frunch
Good Evening AndyT66
Thank you for your reply.
My land Rover is 10 years old (08 registered.)
Any relevant pictures would be appreciated.
Regards
Post #744281 5th Dec 2018 10:10pm
LR90XS2011
www.defender2.net/forum/topic40794.html?hi...oor+handle DEFENDER 90 TDCI XS,
Post #744283 5th Dec 2018 10:16pm
