Home > Puma (Tdci) > Piston cooling jets
NickMc
Piston cooling jets
Thought some of you might like to see the difference between the old and updated parts.
Old style:
Updated part LR019899, much bigger with maybe a non return? Brazed together too:
Shows the new part fitted and the cut out in the piston and the port in the piston skirt it fires into:
Post #744103 4th Dec 2018 11:29pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Where you able to change then by just removing the sump? I remember looking at the manual and couldn't quite decide if more had to be removed or not.
Post #744107 4th Dec 2018 11:49pm
Interesting, thanks. I didn't realise that they were visually different and that is useful to know.
It's also counter-intuitive since there appears to be nothing complex in the old one which would cause the hysteresis problem, but the new one looks like it might!
I believe that the ladder frame has to come off, making it an engine-out job.
Post #744111 5th Dec 2018 12:20am
MK
Does it mean that even the old style is sopposed to do the job they are not as good as the newer type? Puma 110" SW
Post #744114 5th Dec 2018 1:01am
NickMc
That’s what I was trying to work out, I think you maybe could but it would be super super super fiddly to do. I guess they’ve made them so there’s instant and even pressure?
But yeah definitely think it would be an easier job with it out of the car and the ladder frame out. There is a window in the ladder though.
Post #744116 5th Dec 2018 1:18am
hornet
Maybe he bought a piece too much and could cut one open for us in length Smile ?
Post #744139 5th Dec 2018 10:07am
NickMc
Funny engine- three different standard piston and rod lengths alone- why ever will they think of next? Rolling Eyes
Post #744425 7th Dec 2018 1:39am
MartinJC
South Africa 2014 Defender 110 Puma 2.2 SW Fuji White
Are these a JLR mod to the standard Ford Engine, or common to all ford 2.2 Engines! 2002 130 td5 Gameviewer
2004 110 td5 SUV
2012 110 2.2 HCPU
2013 110 2.2 PU Gameviewer
2014 110 2.2 SUV
2018 110 Traxxas RC
Post #912247 13th Jul 2021 8:13pm
