![]() | Home > For Sale & Wanted > [For Sale] Ring RPP265 33AH Jump Starter 12V / USB / 240V in |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1335 ![]() ![]() ![]() |
Thought I would offer this on here if anyone is interested before it goes on eBay.
Top of the range Ring RPP265 boost start pack with a 33Ah battery. Just fitted it with a brand new battery that I purchased from Ring. It claims to be capable of starting a 3500cc vehicle and spun over my 2.2 Defender easily several times in the past when the battery was flat. As well as a boost starter it has a built in 240V socket (300 W max), USB and 12V cigar socket outputs snd a built in LED array work lamp. Reverse polarity check when using the jump leads. LED indicators show internal charge and state of battery on vehicle being jump started. Can be charged through the 12v cigar socket, vehicle to vehicle, or by using the mains charger. The unit sits on a tidy charging base, so no need to connect the charger directly to the unit. Although the mains charger will plug directly into the unit if you want to leave the charging base at home. More details here : https://www.ringautomotive.com/en/product/RPP265 £125 or nearest offer, plus £16 postage due to the weight. Reduced to £120 including postage. Or welcome to collect from Skipton area, North Yorks. ![]() ![]() ![]() ![]() ![]() |
Price dropped to £120 including the postage.
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 196 ![]() ![]() ![]() |
Yes please pm sent
Sold to Tegner. Thanks.
Arrived today many thanks
