Home > Off Topic > Removing stubborn nuts with heat |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
That will do the job. I’ve used it many times for the purpose.
3rd Dec 2018 8:22am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
These also work well but are a more expensive solution:
https://www.sykes-pickavant.com/products/w...ating/1802 |
3rd Dec 2018 8:59am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
Cheap propane torches aren't hot enough. MAP gas works a treat!
Interesting you're having trouble with swivel bolts though, mine flew out |
3rd Dec 2018 9:02am |
You could always go down the oxy-propane route at home. For some reason it scares the neighbours (and insurers) less than oxy-acetylene, plus it can be moved more safely.
3rd Dec 2018 10:10am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Also give the bolt heads a good whack with a hammer to break the loctite seal.
3rd Dec 2018 10:42am |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
Sometimes it doesn't take that much heat, ive even nicked the wifes "creme Brule"! mini blow torches from the kitchen, she wasnt happy but the nut came off!
A plumbers one would be ideal, also get one of those plumbers fire proof mats to place around it helps alot if there is rubber/paint nearby C |
3rd Dec 2018 11:30am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8053 |
that will work fine on LR sized bolts. not so for argi stuff! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
3rd Dec 2018 1:18pm |
Paullr90 Member Since: 06 Feb 2011 Location: Derby Posts: 93 |
3rd Dec 2018 5:23pm |
Plus they are great for getting the woodburner going nice and quick! Beats a match
3rd Dec 2018 5:29pm |
