![]() | Home > Td5 > Spade connectors for rear windscreen motor |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
They're 2.8mm terminals.
The factory harness uses a latching 2-way connector - ![]() Click image to enlarge I've not been able to find that particular connector - but, have found a similar unlatched connector, which works - ![]() Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 ![]() ![]() |
Cool,
Got any info of where you got the connector from? Rgds A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
ok ebay has loads of 2.8mm spade terminals how about the connector terminal block ? Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
I'm selling them ![]() PM me here or on LandyZone Regards, Paul Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
