Home > Puma (Tdci) > Front shock/shock Tower removal |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20281 |
Start with soaking bolts in WD40 overnight, clean nuts and threads.
When undoing them, take it very easy as they are prone to shear but they should be fine. Just take it easy taking them off and by hand tools. Remove the plastic inner arch sections, two self tappers on each. You should be then able to extract both at the same time though the engine bay with the lower damper nut removed. Then you can work on removing the top mount off of the vehicle. There is a torque figure for the new nuts / rings, contained in the WSM. I think I've covered most things, but anyone feel free to add anything. I'd be interested to hear people's methods of tightening and removing the upper damper mounts ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
1st Dec 2018 12:39am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5648 |
This may help.
https://www.defender2.net/forum/topic16066.html |
1st Dec 2018 6:26am |
