Home > Off Topic > Possibly a dumb plumbing question?
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
We’ve unfortunately got a microbore heating system with 4 of the rads having these twin entry valves on them. I need to remove 2. I’ve turned the supply to the rad off using the stop valve (left) and cracked open the nut by the valve where it joins the radiator to start draining it. Despite a few litres draining, there is still fast flow of water from the bleed valve on the top of the radiator and it sounds like more water’s flowing in each time I empty any off.
To me, that means the stop valve is bypassing and I need a complete drain down and to replace the valves.
Before I phone a plumber (again), is there any way it could be refilling through the ‘out’ pipe? I assume not as I assume it’s a one-way valve jobby.
Post #743177 30th Nov 2018 2:03pm
Caterham
hi doc p.
think you've got a by-pass valve there so you're probably going to have to drain the whole system including the header tank.
if you're talking about the main incoming water supply valve / stop cock then yes it's possibly passing.
Assuming you do have a header or F&E tank as opposed to a closed / pressurised system have you simply lifted the float valve to stop the tank refilling?
good luck.
Post #743181 30th Nov 2018 2:09pm
JOW240725
I'm no expert but it would seem to me the two valves are in parallel so it doesn't have a stop vavlve? If so you will need to drain the whole system Confused James
Instagram @suffolk_rovers
Post #743182 30th Nov 2018 2:10pm
Doc P
Yes, we’ve got F+E tank in the loft.
Sounds like my fears are correct. These valves are hard to come by and our usual plumber’s younger than the valves!!
I’m not confident enough to risk mucking about with such small diameter pipes, so I think I’ll have to ask him what to do.
Post #743184 30th Nov 2018 2:16pm
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Re: Possibly a dumb plumbing question?
Hi Doc, if you take the cap off the one on the right it might have a screw head on top of the spindle, screw it down clockwise to close it, the one on the left will close with the knob or adjuster, good luck
Thumbs Up
Post #743185 30th Nov 2018 2:20pm
Caterham
doc p
you got similar valves both sides I presume?
Post #743186 30th Nov 2018 2:22pm
leeds
Not sure if it is the valves or radiator you need to replace.
If you can get under the floor, then use pipe insulation and freezer spray.
You will have enough time to replace the radiator.
If need more time replace the valve with compression end stops.
Brendan
Post #743191 30th Nov 2018 2:42pm
Doc P
Caterham wrote:
doc p
Both flow and return valves in the same body (at the same end - in and out). Theres a length of copper pipe joined to the inlet hole of the valve which runs along inside the bottom of the radiator. The return is right next to it in the valve body but far away from where the warm water comes out of that piece of piping🙄 The pipe had dropped off the valve so the radiator wasn’t heating up!
Friend of mine knows his plumbing. Had to screw down the balancing screw under the other cap as OJ suggests - which I didn’t realise! Got them off thanks to his and your help.
Thanks all again for the ideas.
Post #743199 30th Nov 2018 3:35pm
Caterham
Shocked
Never come across that before. I presume there's a by-pass feature in so much that if you remove that valve the heating still gets round the system?
Post #743200 30th Nov 2018 3:45pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
you'll need to re balance the flow into that rad again when you re-install.
Post #743211 30th Nov 2018 4:16pm
OJ
Doc P wrote:
Caterham wrote:
doc p
Thumbs Up great job, well done Doc
Post #743217 30th Nov 2018 5:06pm
Balvaig
These valves are obsolete as you probably know. You can turn off the square headed valve and lock down the valve with the inset screw to change the radiator. You have to collect a radiator full of water when you crack the nut connecting the valve to the radiator.
To change the valve you will need to partially or fully drain down the system by turning off the water to the header tank and opening the drain valve on the system. You only need to partially drain the system if the radiator is on the first floor.
You then need to fit a valve at each end of the radiator, extending the existing pipes behind the radiator as necessary.
Not a big job if you have done plumbing before.
Post #743318 30th Nov 2018 11:01pm
J@mes
My house was full of rads with this arrangement on, when I renovated I took the floor up and re routed the pipes to conventionally feed/return from either end instead as I pretty much new I'd end up doing it when one of the valves failed anyway.
British Gas had done a few before I bought the house, and had just clipped the new pipework along the middle of the skirting board. It looked terrible. Rolling Eyes
Post #743332 1st Dec 2018 6:27am
