Home > Maintenance & Modifications > Soundproofing and carpet! Advice needed on what to do... |
Paulcmccormack Member Since: 23 Sep 2018 Location: Newcastle Upon Tyne Posts: 48 |
Loads of good info from everyone. I agree completely that Dynamat os the most expensive option by far. However it does have the luxury of being cut to shape. I suppose it depends if you value your day ,or your dollars. I can see why people use it but for me I'll take the time and just plod along with it but by bit.
As for the alternatives there seem to be literally hundreds from eBay, Amazon, online car shops etc.. So I'm just going to buy one on sheets that's a decent thickness and hope the carpets fit over the top. Also buy a thinner one for the doors and areas that may be a bit fiddly with carpet. The idea of addiing it to the inner of the door cards is a brilliant one too. Will just attack each area bit by bit buy I'm assuming i can write off a weekend at least. Thanks agiain fo the as always useful tips. Paul |
27th Nov 2018 10:27pm |
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 |
@landroveranorak
I take it you used spray glue to fix your carpet, did you find it stuck ok to the sound deadening ? Exactly how I’m planning to do mine but unsure whether the glue would stick ?? Cheers Instagram; @gavin_walding |
28th Nov 2018 9:29pm |
Yulong Member Since: 18 Nov 2017 Location: Aberdeen Posts: 110 |
I too did out my Hard Top with Silent Coat using a bulk pack from Amazon for £80, couple hours of cutting and shaping easy as pie.
MUD panels on the sides totally recommend for anyone just don’t do what I did and struggle with just a couple drill bits that blunt quickly, gets a six or ten pack and it’ll buzz through the tub in minutes. Drill holes, plastic tree fixings, job done. Last piece I got was the bare roof insulated, sourced self-adhesive 4cm thick plain acoustic foam factory cut to size from eFoam for around £60. Oh and the heavy LR rubber mat. Around £500 all-in and an afternoon’s work TOTALLY changed the vehicle |
28th Nov 2018 10:03pm |
Anyone done insulation/carpeting a 110 7 seater? Looking for a realistic time estimate for a full proofing and carpet.
Chassis front, middle and rear Door sides panels etc.. removal of cards. Fitting etc. Roof (wmremoval if headlining etc..) Did you need to remove all the seats/internals or just lift, fit and job done? How easy is it to cut the bits? Not technically but time. Lastly fitting a full set of carpets? |
28th Nov 2018 11:33pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
OP have a look at the search facility on here, middle of the screen just below the banner, it’s a great tool and may give you a lot of assistance 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
29th Nov 2018 6:11am |
Yeah, that's right. It's a high temp spray that came with the carpet. You spray it to both surfaces, allow to go off for a few minutes and then it sticks like the proverbial to a blanket. That included the bare metal of the bulkhead, directly to Silent Coat and to the closed cell foam where that was used. There's a few more details here: https://www.defender2.net/forum/post622546.html#622546 and here: https://www.defender2.net/forum/post635199.html#635199 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Nov 2018 8:01am |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Britpart actually sells pre-cut Dyanamat kits. I have installed a couple of these sets and they do work very well.
Although you can buy sheets and cut it yourself, it's easy to go overboard and wallpaper the whole truck, which really wastes time and money. With the kit, it just gives you what you need, all said out and easy to do. After the Dynamat, (floor and beatbox kit, sheets on the interior roof and over top of the original sound deadening material inside the doors) Genuine carpets were fitted. This combination made a HUGE difference in reducing road noise. https://www.britpart.com/parts/enhancements/defender/dynamat/ Click image to enlarge Click image to enlarge it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
29th Nov 2018 8:05pm |
