![]() | Home > In Car Electronics > Puma live feed? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
What do you mean by "it won't let you?"
Under the plastic cap on the positive battery terminal should be two threaded holes to screw extra wiring to?
It's how the (for example) tow electrics are wired to the battery. ![]() ![]() |
Tommyharris Member Since: 20 Mar 2018 Location: Bristol Posts: 100 ![]() ![]() |
The 8mm nuts on the terminals are designed not to come off so they wont allow me to place ring terminal over and then nut back on.
Positive has a tapped hole on the block but negative has nothing. I thought of sliding a spade under the nut but its like a cone shape stopping me also. |
That nut isn't designed to fit a ring to as it's for the clamp.
For the negative, use a good chassis ground. The tow electrics use a stud below the grommets on the seat box: ![]() Click image to enlarge ![]() ![]() |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 ![]() ![]() ![]() |
A pic would be good
martin,
Thankyou for your time mate. I shall t off to that earth and it should be sorted! Ill put a photo up anyway just to show others what i was on about. You know it would be lovely if landrover had a live loop throughout a defender with points every now and then so you could wire accessories. I dont envy guys in the auto electrical game trying to run wires all day and making stuff look neat |
