Home > Maintenance & Modifications > Soundproofing and carpet! Advice needed on what to do... |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 372 |
I bought Dynamat kit and carpet pre cut from LRi. Only so far done the rear of my 90 and it has made a HUGE difference.
If I did it again I would just buy plain sheets and as the kit doesnt fit perfectly, but its 99% |
25th Nov 2018 11:01pm |
Paulcmccormack Member Since: 23 Sep 2018 Location: Newcastle Upon Tyne Posts: 48 |
Sheets of Dynamat or carpet?
Also read a lot about having marine carpet or van lining stuff. Do the exmore/LRI ones start to smell when wet and soggy? |
25th Nov 2018 11:07pm |
Sorry, sheets of dynamat.
My car hasn't got wet inside so I can't comment on that! Having said that I am going off-roadn Salisbury plain on Saturday so will let you know!!! |
25th Nov 2018 11:09pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5641 |
I used this stuff in my Tdci when I had it.
http://www.wrightoffroad.com |
25th Nov 2018 11:17pm |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 |
I have had my TDCi 90 front, back, roof and all three doors done in dynamat also I have the Mud side panels in the rear you can just see them in the picture below ,Genuine Land Rover rubber mat again in the front and rear all so a carpet in the back over the matting ,this all seem to make the 90 a nice place to be ,I can listen to the Radio at 70 mph ,but it's at slower speeds you really get the full benefit no noise from the rear wheel box's etc ,even the doors shut with a more solid feel,over all definitely worth doing.
Click image to enlarge |
26th Nov 2018 12:05am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20263 |
Dynamat for me, if I ever get the chance to put more in.
26th Nov 2018 12:12am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1617 |
Don’t know if I’d get away with that rear carpet over here |
26th Nov 2018 12:18am |
I saw it and had to have £10 from a boot sale.
26th Nov 2018 12:24am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2142 |
Get the Exmoor carpet, i wasnt impressed with the LRI quality or fit. The floor mats where too large and fell to bits after 3 months (replaced with new) that then fell apart after 6 months. Back then my 110 did about 4k a year so terrible quality imo.
The seatbox fit however is quite tight and rather good. Instagram @defender_ventures Empire Tuning - Agent |
26th Nov 2018 6:06am |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 |
I've used Silent Coat in mine. Great stuff and cheaper than Dynamat. A hot air gun was very handy when fitting.
26th Nov 2018 6:16am |
As for soundproofing, if you have a compressor I would suggest Lizardskin. Used it on my 110 doors, bonnet and underside of the floor pans, makes a huge difference fraction of the cost of Dynamat (excluding the conpressor etc), more effective, easier to apply - but more prep required and greater coverage.
If LizardSkin had be around when I did my interior (Fatmat Megamat) I would have used it instead. If I ever get round to it Ill be doing the roof and bulkhead. Instagram @defender_ventures Empire Tuning - Agent |
26th Nov 2018 7:40am |
Thanks for the Carpet info and verdicts on soundproofing.
I was contemplating buying and making my own with marine grade fabric/carpet, but in reality I doubt i’d Have the time or patience and the results would be ok, but not professional. Same with the Dynanat, it’s expensive and probably no better than all others, but it’s cut to size so easy to fit bit by bit in no time. Anyone have dynanat under an exmore carpet set! Is there enough overlength to join the corners? |
26th Nov 2018 2:09pm |
Take a look at Silent Coat as an alternative to Dynamat. As far as I can tell, it's the same material but is slightly cheaper. I used it in my old 90 and my current 110, along with 6mm closed cell foam, and it's made a huge improvement.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I trimmed the 90 with Veltrim, which is a stretchy material that's glued in place. I plan to use auto carpet in my 110, secured with carpet tape, when I get chance to finish it. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
26th Nov 2018 2:51pm |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Dynamat on the sides of the tub, then silent coat on the roof, plus the rear of mine has rubber Checker plate... and it’s deadened any resonance.
Remember to do the rear quarters at;und the windows too, and the rear door, as well as back of the door cards. Click image to enlarge |
26th Nov 2018 3:16pm |
