Home > Technical > Failure of heated screen
Brucey
Poland 2004 Defender 110 Td5 DCPU Auto Java Black
I have just changed my heated screen due to the original one not working.
It has no moving parts and is not damaged, how can it fail?
The only defect that I can see is that there is traces of corrosion on the electrical tape sandwiched between the sheets of the glass. I notice that on the new screen (from Masai 4x4) the bottom and top of the glass is sealed with a black paint.
I was looking for option to repair the original (as a spare)....doesn't seem likely. thoughts please?
Chris
 Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #742310 26th Nov 2018 10:46am
Balvaig
You need to get the circuit tester out. Check for continuity on the main elements, and the connectors at the bottom of the screen
The elements do break, and corrosion can cause electrical faults.
Post #742323 26th Nov 2018 12:38pm
Litch
Had heated screens on my 90 for about 16-years and while I have never had one fail completely, breaking of individual elements is very common. It can be after just a couple of years that a misty or frosty screen will clear but leave stripes which take a bit longer to clear due to elements breaking. ONE LIFE, GET IT!
Post #742325 26th Nov 2018 1:01pm
c18rch
United Kingdom 1988 Defender 110 200 Tdi HT Keswick Green
I have exactly the same symptoms as you describe with mine.
Have already started to fault find, but haven't managed to work it out yet.
With mine it just doesn't work ata all. Nothing is heating up. Have viewed it with a thermal vision scope. No change in temp compared with non-heated parts of screen.
I have done a continuity test and that is fine.
The voltage supplied is correct.
I have checked the current draw and that is what I would expect too.
I have replaced the earth for both windscreen and relay.
No joy.
The only thing I can think is that it is somehow shorting to earth somewhere but not enough to blow the fuse, ie mimicking the screen working but without heating the elements.
Anyone got any other ideas? 1988 110 200TDi Hard Top
Post #742335 26th Nov 2018 2:23pm
