Home > Puma (Tdci) > Intermediate shaft O ring change
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
I'm about to change the intermediate shaft o ring, do I need to replace the crush tube or can I back the nut off enough to replace it and re-tighten. Thanks
Post #742281 26th Nov 2018 6:33am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Pat I have a 2014 Puma and I found that the crush tube was actually a machined to length tube.
I had the local land rover repairer machine the case for a penny washer to eliminate any more leaks.
Mark
Post #742289 26th Nov 2018 8:10am
Roy5695
I’ve just changed mine. On the later spec transfer box’s it’s a spacer not a crush washer so as long as you get the right preload on the bearings afterwards you should be good.
Depending on the age of the box and which end it leaking. The casings are prone to ovaling so will just leak again. Also recommended to fit the shaft with some form of sealant on each end. I used an RTV. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #742326 26th Nov 2018 1:05pm
