Home > Maintenance & Modifications > Ipad mount
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Ipad mount
I have my ipad in an otterbox case which i would like to keep it in and mount it on the dash but also in the rear when we sit down in the evening
I've found this;
https://www.ram-mount.co.uk/quick-release-...hg9eli20c2
but it's only a 1" ball and i'm not sure what kind of weight the 1" ball can take and keep it steady.
Does anyone have an ipad (pro 10.5) on a 1" Ram mount?
Post #741946 23rd Nov 2018 9:20pm
WindyJ
Solid as a rock.
Post #741947 23rd Nov 2018 9:25pm
leeds
The standard B ball system will take 1 Kg which is plenty for an iPad.
Not seen that particular mount we use the X grip system which is fine for iPads.
Brendan
Post #741949 23rd Nov 2018 9:39pm
Badger110
I like it as it’s less obtrusive when the iPad’s not there
Good news that it’ll take the weight Thumbs Up
Post #741951 23rd Nov 2018 10:08pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
We have Panasonic Toughbook tablets fitted in our vehicles using the RAM system, absolutely solid. They get a lot of knocks and bumps, the only time I have seen them damaged is when people who are too lazy to slacken off the clamp and try to force the thing into a different position. Even then it takes years of abuse before they are actually ruined. Best mounting system out there as far as I’m concerned.
Post #741957 23rd Nov 2018 11:05pm
TJ101
I ran a toughbook, in one of these https://www.ram-mount.co.uk/tough-tray-uni...1_615.html but on the larger ballmmm was a tad heavy for the 1"
The full size I pad is fine on the 1",, no bother,,
I use in this mount https://www.ram-mount.co.uk/apple-ipad-min...6_677.html California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #741959 23rd Nov 2018 11:20pm
You can use the claw clamp on the grab handle too, then is totally removable. Chillin In The Backwoods🇬🇧🇺🇸
Post #741963 24th Nov 2018 12:19am
