Home > Puma (Tdci) > Actual oil pressure for 2.4 tdci
MGRGPGBG
United States 2009 Defender 110 Puma 2.4 SW Alpine White
I am measuring idle at 5 bar / 72psi on a mechanical oil pressure gauge plumbed into the oil pressure switch port.
This pressure seems high. What are actual pressures you guys have tested on your engines?
Post #741695 21st Nov 2018 11:13pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
The workshop manual states:
Quote:
Engine - 2.4L Duratorq-TDCi HPCR (103kW/140PS) - Puma
Oil pressure specifications
Minimum oil pressure at idle speed: 1.25 bar
Minimum oil pressure at 2000 rpm: 2.0 bar
So yours is 4 times the minimum pressure at idle. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #741710 22nd Nov 2018 8:07am
Naks
Cold idle is anything between 5 & 7 bar depending on the ambient temperature.
Hot idle is 1.6 bar Thumbs Up --
Post #741711 22nd Nov 2018 8:09am
dorsetsmith
ford engine oil system work on high pressure low volume
Post #741715 22nd Nov 2018 8:46am
MGRGPGBG
Yes - I found those values in the manual, but have not been able to find what the “typical range” is.
Post #741753 22nd Nov 2018 2:09pm
MGRGPGBG
Are these values on your truck or where did you get these values from?
Post #741754 22nd Nov 2018 2:10pm
Naks
these are on my 90, they've been like that since I bought it new in 2010.
I have a Madman EMS installed, so I can see the oil pressure, coolant temp, transfer box temp, and EGT in real time.
Post #741760 22nd Nov 2018 2:52pm
MGRGPGBG
The EMS2 gauge that I installed is what started my questions. I pulled the sensor to put the mechanical gauge on and I was under the impression that 5 bar was too high as Madman now supplies a 0-5 bar sensor as standard unit.
Post #741761 22nd Nov 2018 3:26pm
Naks
5 bar for cold idle is not that high, I've seen mine go up to 7 in winter (when I still had the old 10 bar gauge).
what is important is hot idle, just make sure it's between 1.4 and 1.7, every engine will be slightly different, but as long as it's above 1.2-1.3, you're fine.
Set your alarm for 1.2 bar, so that if the engine loses oil, you have ample warning before a catastrophic seizure. --
Post #741767 22nd Nov 2018 4:02pm
MGRGPGBG
Thanks- good to know, I thought I might be over analyzing this.
Post #741770 22nd Nov 2018 4:39pm
Naks
IIRC, these are my other alarms:
EGT: 650C
Coolant temp: 101C
Transfer Box temp: 110C --
Post #741775 22nd Nov 2018 5:30pm
MGRGPGBG
Oil Pressure started out at 4.5 bar and when engine was warmed up it settled into 2+ bar.
Thanks for the information.
Post #742355 26th Nov 2018 4:01pm
Naks
2+ bar at hot idle seems high to me --
Post #743336 1st Dec 2018 7:28am
hornet
There is a difference of approx. 0.4 barg for warm oil (>50°C) depending on viscosity. If I use 10W oils, I land at 1.6barg and with 0W oils the pressure corresponds to the manual specification.
Post #743947 4th Dec 2018 11:50am
redline
Switzerland
Oil pressure will be highly dependent on oil viscosity, ambient temps (when car is cold) and engine rpm.
I'm also using a Madman gauge, and was going nuts at the beginning as I was seeing very different values, and couldn't figure out what was normal.
When the car is cold in summer, I see over 4.5 bar at idle. In winter (cold car) I often see over 5.5-6.5 bar at idle.
The only comparable (and reliable) values are when the car is warm, and at idle: With the recommended oil-spec I see 1.6-1.7 bar.
Also noteworthy is that I had an intermittent issue with the sensor, that was going to full-scale, and reading maximum values over 10bar... even when the car was off Laughing Changed sensor fixed that.
Post #744788 9th Dec 2018 12:03pm
