Home > Maintenance & Modifications > Windscreen wiper recommendations please
Cupboard
What do you use and are they any good?
I've had a set of Bosch Aerotwin for a couple of years, they were quiet but never cleaned the 1/4 of the windscreen in front of my eyes.
Recently I bought a set of wipers from Paddocks and they're the "Iguana" brand. The clean the windscreen perfectly but screech irritatingly.
I'm after a set of wipers that are quiet and clean the windscreen. Any ideas?
Post #740917 17th Nov 2018 10:26am
edo
Bosch Aerotwin here - seem fine.
Post #740922 17th Nov 2018 10:51am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
I've tried a few and most work fine if you change them periodically e.g. at service time.
They are cheap enough now for the Defenders - can be 3-4 pounds a blade if you shop around.
Post #740923 17th Nov 2018 10:57am
Balvaig
Just fitted a set of LR originals from Dan at Duckworths (site sponsor).
Good price, delivered to my door.
Work as they should - clear the screen fine and are quiet.
I also use RainX windscreen cleaner, which seems to help too.
Post #740929 17th Nov 2018 11:42am
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
I use Aerotwins plus rainX, not perfect but best I’ve had 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #740943 17th Nov 2018 12:59pm
Sulisuli
Areotwins front and rear combined with using GTECHNIQ G1 clearvision, far superior to rainX one coating a year and the results are excellent. Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #740950 17th Nov 2018 1:37pm
williamthedog
I buy bearmach ones every year when I do the service on mine. I fit them at the start of the autumn to get the full benefit. Think they cost me under a fiver. Thumbs Up
Post #740954 17th Nov 2018 2:28pm
Martin
Site Admin
Bosch Superplus here Tried many others including the flat ones (Aerotwin) and the standard type Bosch are the ones I stick with now Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #740958 17th Nov 2018 3:43pm
Bosch aerotwin, rain x and Motul Apple screen wash.
All good. Mr. Green No Guts, No Glory.
Post #740965 17th Nov 2018 4:32pm
Cupboard
Right, so far the best option seems to be the different Bosch ones.
With the Aerotwins I know it wasn't just one faulty wiper because it was the same on both sides of the windscreen. The top 5cm was wiped, then there was a 10cm gap of smeariness where I looked through, then the bottom 15-20cm was clear.
Thanks all Smile
Post #740968 17th Nov 2018 4:41pm
L110CDL
I use these now ....................
In my mind the aero twins did not last as long as i hoped Rolling Eyes these are very good and don't make any noises and clean the windscreen good, i also clean the windscreen with Autoglym fast windscreen cleaner Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #741363 19th Nov 2018 10:12pm
keith
No one seems to have mentioned PIAA wipers. I'm sure there was a group buy couple years ago but didn't go anywhere.
I bought direct from PIAA but not cheep at £50. Very good but only lasted same time as genuine and Bosch.
Keith
Post #741382 19th Nov 2018 11:43pm
NickMc
I just buy the Rainy Day 33’s by the box and it works out very cheap. I could buy a fair few boxes for £50!
Post #741386 20th Nov 2018 12:11am
Rashers
Got really fed up with my windscreen wipers and noted that the drivers side one was splitting.
As mentioned in another post, I had been considering Kelmarsh Show and as the weather was iffy, didn't want to chance the wiper failing.
Read through this post after doing a search and ordered some Bosch Superplus wipers (like Martin and Clayton recommended) from Opie Oils. 1st class service and I am very happy. I also tried the GTECHNIQ G1 coating on my windscreen (as recommended by Sulisuli). Had tried RainX (albeit a long time ago) and had never had a lot of luck. It was great at clearing the rain, but was not overly great once the wipers were switched on. The G1 is first class. Three coats on the windscreen, one on all other windows. The amount supplied just about got round my 110 Utility. It would be fine for a normal car and loads for a 90, but you may struggle with a SW if you want to coat all the windows.
I am well chuffed with the G1 and Superplus combination. Thank you Gentlemen for your recommendations and advice
Thumbs Up
Post #784878 4th Aug 2019 5:20pm
Sulisuli
So pleased you liked the GTECHNIQ G1 , it’s not cheap but lasts for ages think I have done 10k miles since the last coating Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #784883 4th Aug 2019 6:35pm
