Home > Technical > Floor mounted seat belt bracket - Defender |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1661 |
Picture speaks a thousand words! You don’t say if it’s a 90/110/130 or Td5 tdci?!
19th Nov 2018 7:17pm |
I'd hazard a guess that it's a 2008 90 CSW in Java Black
Tim, I think you're stuck with having to drop the tank. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
19th Nov 2018 7:36pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8153 |
Magnet on a stick down through one of the bolt holes to locate it and lift it up, get one bolt in the other hole then to hold it. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
19th Nov 2018 8:29pm |
Timbo66 Member Since: 14 Oct 2018 Location: Leicester Posts: 37 |
Thanks you both for the suggestions. I’ll try the magnet route first before dropping the tank.
NickMc - it is a 90. Does this help with your reply/suggestions? |
19th Nov 2018 11:00pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 |
If it has the nuts on the plate, use a bit of threaded bar. That way you can slot over the fitting, then use other bolt, remove threaded bar, use second bolt.
19th Nov 2018 11:19pm |
Thanks for that, I'll give it a try tonight!!
20th Nov 2018 12:48pm |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 |
No more help than the guys above, fishing with a threaded bar being a top tip.
perhaps the image may be of some help |
21st Nov 2018 1:27pm |
21st Nov 2018 8:54pm |
Sadly neither the magnet nor the threaded bar worked
Started to remove the cradle to get a chance at getting to it from beneath. 5 broken nuts later from underneath I’m left with the two nuts in the rear bumper area. Normal socket won’t fit, so I need s deep socket. Does anyone know the nut size? Thanks |
26th Nov 2018 8:23pm |
All sorted
Thanks for the advice all. |
26th Jan 2019 3:40pm |
