Home > Maintenance & Modifications > Still leaking - passenger footwell
Mwd
I few weeks ago I had water leaking into both footwells so I used tiger seal to seal across the foam gasket between the bulkhead and window frame, as well as behind the windscreen blocks (these had been refitted too soon after painting by the bodyshop who replaced the windscreen frame under warranty and the new paint had crinkled, leaving a poor surface for the rubber gaskets to seal against). The driver's side is now dry but I still have water dripping down behind the dashboard on the passenger side, appearing where the door stay is attached and dripping down onto the mat. The door seal looks OK (by Defender standards) so I suspect the culprit is somewhere else.
Where are the most likely places for me to check next?
Thanks
Post #740476 14th Nov 2018 11:38am
Balvaig
Does it depend on the angle the car is parked.
My leak was coming from the front gutter, which was dripping down onto the door seal at the kinking the door. This then ran into the car along the check strap and onto the mat. The door seal can also crease just at this point.
I fitted a new door seal and put a blob of mastic at the front gutter discharge point to divert the water away.
Post #740479 14th Nov 2018 11:46am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
I found some holes in the foot well driver side - I wonder if it may be the same passenger side? Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #740489 14th Nov 2018 12:47pm
Adam17
 Regards
Adam
Loving The Duchess
Post #740490 14th Nov 2018 12:48pm
Grenadier
My leak was the same as Adam's. Holes at the top of the driver's box. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #740498 14th Nov 2018 2:32pm
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
Water running off the end of the channel under the windscreen runs into the engine compartment and goes down the bulkhead inside the engine bay. The water sometimes runs between the heater box and the bulkhead due to the seal deterioration. To alleviate this problem Land Rover supply a part LRO38612 Seal Fender which deflects the water forward along the wing so that it runs into the engine bay above the wheel arch.
The fender seal on the o/s will stop water running onto the control pedal area. Although on mine I only fitted one to the n/s.
I think there are 2 separate part nos for ns/os parts but I am not sure.
This cured my water ingress problem on the n/s.
I hope it helps
Post #740514 14th Nov 2018 4:27pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
What foggy has said.
You can , if your dash is out, trace where the water comes back in and from the inspection under the bonnet, I can confirm it comes off the channel.
Extend the channel
Post #740530 14th Nov 2018 6:09pm
Adam17
I hope it helps
when I was trying to find my leak I noticed that the water was pouring from the window channel into the engine bay and running down the bulk head... I was trying to think of a way to channel the water further from the engine bay..even over the outside of the fender, completely away from the engine bay..
If I come up with anything ill let you all know.. I will check out the part numbers above, but think I would rather stop the water from getting in the engine bay than deflect it inside the engine bay..... Regards
Adam
Loving The Duchess
Post #740666 15th Nov 2018 12:08pm
foggydave
The Fender is about 6-8 inches long and provides a lip to stop the water. You could affix a strip of material all the way along the inside of the wing which would be effective. Or a channel section (gutter) fixed along the inside edge of the wing.
Post #740688 15th Nov 2018 3:01pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Try as I might I cannot find this Fender thing or part number listed Question
Probably bad Google foo on my part but would welcome a link if possible please.
Post #740743 15th Nov 2018 8:52pm
foggydave
Sorry it seems I put O instead of 0 (zero)
LR 038612
Post #740754 15th Nov 2018 9:55pm
8619simon
Thumbs Up
Post #740870 16th Nov 2018 7:53pm
Mwd
I hope it helps
My Defender is fitted with these but the N/S one wasn’t sealed to the bulkhead so water has been dribbling down the engine side of the bulkhead. I refitted it with some sealant. The one on the O/S had fallen off and was wedged in the wiring and brake pipes below the wing. Refitted that one too, so now I need to get the hosepipe out to test it, or wait for it to rain. Thanks for the tip!
Post #740890 16th Nov 2018 9:39pm
