Home > Maintenance & Modifications > Viscous fan removal tool
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Made a simple tool
Distance between holes 70mm
Bolts 25mm m10 coach bolts
Drill 2 holes in something substantial that’ll take a wee bit of sideways movement ( I found a piece of aluminium about 6mm thick )
Insert bolts, nut them up, job done Thumbs Up
Using a 36mm spanner on the nut, give it a tap with a hammer anti clockwise and off you go
Post #739814 11th Nov 2018 10:42am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I have a spanner I put on the flats. A short sharp hit with a hammer cracks it loose enough to undo it normally 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #739830 11th Nov 2018 12:46pm
gazman
Post #739831 11th Nov 2018 12:51pm
Badger110
I did try that to start with, but it didn’t help.
This allowed the slight tension on the pulley for the tap to be effective
Post #739838 11th Nov 2018 1:37pm
Cupboard
Why didn't I think of that?!
I was having that exactly problem last weekend.
Thank you Smile
Post #739847 11th Nov 2018 2:07pm
