Home > Technical > Handbrake Electrical Short |
earthing
8th Nov 2018 7:16pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5771 |
Check vehicle earths.
Often the earth to transfer box. The vehicle is using handbrake cable as the earth cable |
8th Nov 2018 8:58pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
As others have said, but also check brake fluid is nearest the upper max mark too. KEEP CALM AND Drill ON
8th Nov 2018 11:43pm |
handbrake wiring also go up to the brake fluid level switch
9th Nov 2018 7:46am |
Nuge Member Since: 04 Sep 2017 Location: Den Haag Posts: 2 |
Thanks everyone. It's definitely the chassis ground. I put a jumper from the battery negative post to the chassis and the issue is gone. I will install a new chassis strap.
10th Nov 2018 5:18pm |
10th Nov 2018 5:45pm |
good
10th Nov 2018 5:46pm |
