Home > Technical > What’s this hole!!!???
Page 1 of 3 123>
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Hi folks can you tell me what this hole is on a Defender Puma bulkhead....
 @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #739365 8th Nov 2018 5:26pm
DAZ110
Is that not where the gear-lever comes through?
Post #739369 8th Nov 2018 5:40pm
Drain from the a/c chiller in the heater box.
Post #739370 8th Nov 2018 5:49pm
Steve_overland
Hey mr wolf are you certain that is what it is ... I’m asking for a mate who’s bought the bulkhead @steve_overland on Insta.
Post #739379 8th Nov 2018 6:41pm
Eduardo
As DAZ said for the position looks like the hole for the gear levers
As display in the workshop manual...
Cheers and good luck Eduardo
Post #739387 8th Nov 2018 7:14pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
It’s not the gear selectors , they sit forward (technically it’s towards the rear of the truck ) of that section of the bulkhead.
It’s not to do with A/C either
I’ve just removed the heater matrix from a 2011 a/c fitted defender and the hole isn’t cut out
Post #739391 8th Nov 2018 7:39pm
Aha, the a/c drain is the small round hole nearer the centreline, visible in the photo above.
In which case I have no idea what the big hole is for, but it's definitiely not the levers.
Post #739431 8th Nov 2018 10:39pm
jst
Sunroof drain? Sorry not helping.... Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #739438 8th Nov 2018 11:03pm
^^^ Need a bigger hole than that James! Laughing
Post #739451 9th Nov 2018 6:59am
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
It’s for letting all your money fall out of. I’ve got one.
Post #739454 9th Nov 2018 7:38am
donmacn
I'm intrigued now! Not because I have one of these in a Tdi, but because that's a pretty big hole, and the accumulated wisdom of Defender2.net hasn't pinpointed it yet - which is pretty unusual.
I'll have to 'follow' this now to satisfy my curiosity.
Also intersting to notice just how much soundproofing is on that bulkhead in comparison to the Tdi. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #739467 9th Nov 2018 8:47am
VVS210
Wondering whether it might be something to do with a power take off? Not sure if Pumas had these but maybe if the bulkhead was from an ex utility spec vehicle - does your mate know the donor vehicle?
Post #739469 9th Nov 2018 8:58am
The only PTO options on a TDCi are those which pick up on the LT230 in the same way as earlier vehicles, so it won't be PTO related.
On a fully-assembled vehicle the top of that hole will be slap bang under the heater unit and completely inaccessible, whether RHD or LHD it makes no difference. It really is a bit of a mystery, especially as some clearly have the hole punched out and others just have a flat unpunched area.
The size suggests an access hole. It is possible that it is an artefact like the unused "gearbox mounting" on the crossmember below the MT82, which I think only exists because the MT82 CAD pack says there should be a mounting there. Perhaps it similarly says there should be a hole in the floorpan above the MT82 to allow access to the clutch pipework.
I hope that we can bottom this out, it is fascinating!
What age is the bulkhead with the hole? Is it an early one?
Post #739474 9th Nov 2018 9:30am
Huttopia
What he said! Rolling with laughter
Post #739486 9th Nov 2018 10:34am
NMBRPL8
Australia
It was introduced with the defenders around 1990 so to lower weight to enhance high speed cornering
Post #739491 9th Nov 2018 11:02am
Page 1 of 3 123>
