Home > Puma (Tdci) > Does the Puma heater get air in it easily? |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
Ever since I bought my 2.2 I have noticed that the heater is less effective when the engine is running slowly (low speed & load in light off road use for example, or sitting at idle for a period) and I just put it down to 'one of those things' as it was plenty hot enough when running at any speed. The coolant level was very slightly below the cold line but plenty in the header tank so had never worried about it much.
The other day I happened to have an open can of OAT antifreeze and some distilled water to hand after a job on one of our other 110s so I topped it up to the line - no more than half an inch added in the tank. Now the heater works significantly better at low engine speeds. The only explanation I can think of is that the engine was cycling a small amount of air around which when idling, would settle in the heater matrix, but then be forced out by the higher flow of the coolant pump when the engine was working harder. Is this a known 'Puma eccentricity'? There are no other symptoms of anything amiss. Did a search but nothing firm came up. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
6th Nov 2018 10:27am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8145 |
I have just done a stat change, header currently overfilled, heater is really hot! Yes its all bled through! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Nov 2018 6:47pm |
Nice one, made me chuckle. Thanks, something to keep an eye on then. It does still fluctuate between hot and hotter but much less than before. Wife likes her footwell to be in the Sahara while I drive with the window open in winter, so the mismatch in temp is spot on --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
6th Nov 2018 9:12pm |
